Anonymous-0
Does anyone know how to connect a remote hydraulic valve for running external hydraulic cylinders? I know you are suppose to connect into the hydraulic manifold on the side of the tractor and you have to change the control on the block to HYD Equip. setting, but that seems to make the 3 point hitch not work. I need all of it to work at the same time. I was told I had to have a powerbeyond valve but it has an inlet, outlet and power beyond port. I only have an outlet and an inlet port on the hydraulic manifold on the tractor. If someone knows how this is suppose to work and could explain it to me or if I had a schematic of the tractor hydraulic system I could figure it out. Thanks Joe
