REYESMR808
New User
Hello,
Have a TW-15 4WD, UC515M Serial # C750232, so I believe it is a 1985 model. I just came to own this, so I am not very familiar of what 'normal' is for it, and very little images to share of what before looked like.
Found a broken belt that seemed to go to the alternator and the water pump down to the main crank. I am trying to figure out which belt I need to buy and learn if the belt for the alternator also goes around the water pump pulley, or are the belts in a different configuration.
Currently, have two belts still installed, but when looking at the various pulleys that are available, I see that the hydraulic pump has an inner grove (2 total) that a belt could also go on, with the outer groove of the hydraulic pump going down to the main crankshaft.
Does a TW-15 a 3 belts or 4 and what would be the configuration be for them (i.e., Does the alternator belt also run through the water pump pulley, or does the water pump have a separate belt that goes to the inner track of the hydraulic pump?)?
Thanks in advance for any help!
