Noel Putman
Im trying to wire a 5 position switch so that I do not burn up
the tractor with the thermostart feature.
The terminals are wired 1-5. Am I right in assuming that 1 is
the run position with power to the instrument panel and
lights. 2 would be the thermostart. 3 would be power to
starter solenoid. The manual is a bit fuzzy on where the
wires go on a 5 position switch.
Thank you.
Thank you.
