I need help identifying this filter on a ford 4000 1971
Hello Tac welcome to YT! Just recently the forum host
here changed the requirements to new posters to be
able to post photos from a post count of 5 posts to 1
post. You need to try again with posting your picture. It
should go through on your second post if everything I
understood about the change is correct. I believe this
change was only made on ..Modern View.. so you need
to post from there. In Modern View you will see the
Classic View option in a red outlined box at the top.
The restriction was a way to keep internet bad guys
from dropping in and posting bad pictures with hidden
viruses. Pictures post through the ..Choose files.. or
some such name button down lower in the ..New post
and reply windows. They cannot be pasted into the
text area as a file.
It is the screen for your hydraulic pump.
Here is your photo from the other forum.
I replied to you there.
