Daniel in PA
Hello
Wanting to add Thermostart to my TW-5 thats never had it, had ether start at one time, I assume the port in the intake tube is the same size. Installation should be straight forward, I’ll use the ether bottom thru a solenoid for the heat. Where would the tee in the return line be located? It already has one behind the upper fuel tank, going to the upper tank, lower tank and injector return.
Thanks in advance.
This post was edited by Daniel in PA on 12/08/2022 at 03:48 pm.
Thanks in advance.
