1700 questions
I have two questions about a Ford 2WD 1700 I recently purchased. Tractor has 11.2x24 ag. tires
1. Someone welded up a hitch tongue on the back which I think is too high. How far below and from the end of the P.T.O. shaft should the pin hole be?
2. Any time the 3-point arms are anywhere but completely down, the engine labors, which leads me to believe the hydraulic pump is working. Is this an issue with the load control?
(quoted from post at 08:01:49 12/08/22) I have two questions about a Ford 2WD 1700 I recently purchased. Tractor has 11.2x24 ag. tires
1. I don't have a 1700 but do have a 1620 (HST version of the 1720) and a 1510. The drawbar hole on the 1620 is 7-1/2 inches below the PTO center and adjustable front to back with several mounting holes to suit the condition. The 1510 has a bracket 5-1/2 inches below the PTO.
The 2nd problem is alittle trickier. If the lift arms are raising and lowering as they should, I would change the hydraulic filter first and then make sure the position control rod is not bent and adjusted properly.
Both my Fords and a Kubota will load the pump if the position lever is pulled all the way to the top stop. I made a little lever block for the 1620 as shown.
