1801 ford part number
AndrewJ
Does anyone know the part number for item 71 of the lower part of the upper cable sheathing for the steering on an 1801 ford? It shows it in the diagram as 71 but when you go to the parts listing to find the part number it skips from 70 to 72.
Thanks for any help.
These part numbers will work for what you are looking for, however they might be marked for a 4040 since the C is for the 1960s. The 1801 parts number generally started with a B since its a 1950s. If you can find an old Ford Tractor dealer that was around in the 1950s that is a good place to look. I was able to go through two dealerships(that were around in the 1940's) that were closing years ago. I found some NOS stuff and good gently used parts, but not enough to make a full steering kit. Most of it was not in its original packaging and was in crates and boxes. Its good to take pictures and measurements of the parts you need for comparisons. This was a popular topic here on yesterdays tractor about 10 years ago, there are some good posts. I have not seen any parts come up for sale in a long time, but I gave up looking for them years ago.
