[email protected]
New User
Hello,
I believe I have a 1958-1962 Ford 801 Powermaster. I m new to tractors and the tractor was deserted on family property and we are in the process of getting it up and running. VIN # is near impossible to identify due to battery acid or grinder, hard to say for sure. After days of research, I think I have a 861. The tractor is a 5 speed, live PTO and has the 172 Diesel motor. So! Tons of questions but for starters. Can someone simply tell me how the manifold glow plugs are wired. Current condition is two plugs with a jumper wire connecting the plugs. Then a terminal with a corroded off wire. There is no other wire to trace back to the corroded terminal so I have no idea where the manifold heaters get power from. Through research I think it would go up to the push button bc it needs to be pressed 20-30 seconds prior to starting the tractor. We have been able to get the motor to turn over but won t fire and start. I assume the manifold heaters are a MUST in order for a successful start? The tractor last ran 6 years ago and prior to that 10-15 minute use, had not been started in 10 years. Also, suggestions on where to get new wiring or all new harness for this tractor? All the wiring is clearly in bad shape.
Thank You,
Collin
Thank You,
Collin
