FOMOCO Farmer
I think I know what happened but wanted to get others opinion. I've noticed a noise from the front of the motor the last few days. Tractor has been bushhogging. Not pulling all that hard. Yesterday, I smelled something that was not right. Noticed smoke or steam coming from the front of the motor around where the top radiator hose attaches, first thought was blown radiator hose. Tractor was not running hot. Started home, motor labored and quit. Pulled it home, cranked it over with kill switch pulled, no noise, pushed kill cable in and it started. No oil pressure in either port with a mechanical gauge. I'm pretty sure the oil pump drive idler gar has fallen off. Question is, right before it quit, it had excessive blow by. It blew out the dipstick and breather tube. After the restart, it had no blow by. Can anyone explain this? Motor ran fine. I did not run it long. I'm pulling the pan and see what I find. Probably pulling some rod caps as well. Anything that doesn't look right, motor is getting rebuilt. Tractor has around 5500 hours. Any thoughts, opinions are welcomed.
