Ford fuel banjo bolt
Ford 600 tractor fuel sediment bowl.I have the 38 version are there 2 different 38 banjo bolts .if so is hole that is drilled in side of bolt different location.would it matter which way fuel line points towards motor or away .the current one I have the hole in side of bolt is closer to threaded end
I have mounted my sediment bowl in both directions, fuel line in and fuel
line out, using the same banjo bolt and it made no difference for me.
Originally the fuel line pointed in on both of mine that are now out.
Thanks royse .I think I have seen you rerout the fuel line towards front of motor and
point sediment bowl line away from motor.if so how long of brake line did you use.
A number of us have done that and many have done a much
prettier/neater job than mine. I just bought the brake line in
a longer length, cut it to size and double flared the ends on.
(quoted from post at 20:43:06 11/22/22) Ford 600 tractor fuel sediment bowl.I have the 38 version are there 2 different 38 banjo bolts .if so is hole that is drilled in side of bolt different location.would it matter which way fuel line points towards motor or away .the current one I have the hole in side of bolt is closer to threaded end
f the fuel flows, you will know all is well. If not, you will know bolt hole and channel do not align. Easy peasy.
I just bought the brake line in a longer length, cut it to size and double flared the ends on.
I don't have a double flare tool & like a "real" fuel shut-off, so I cut to length & add a 1/4 turn lever ball valve w/2 compression fittings.
Not greatest luck with those .there is a inline flaring tool titan inline flaring tool
take a look .I might buy one ill let you guys now how it is .lots Uribe vids
