801 Clutch release bearing hub
Lynn Patrick
The hub that carries the throw-out bearing on my 801 5 speed is broken. This site (& others) carry one for serial #14xxx & up, but mine is #13xxx. Will the new one work? Thanks!
You can see on mine the fork fits past the rest of the hub (one is broken off):
Theirs is level:
Problem solved!!
Friend (retired professional welder) stopped by today. He took me to a friend of his w/a welding shop where he found the rod he wanted, then he ground, cleaned, & welded my hub together! Looks good & will probably outlast many other parts of this 801!
