Ford 640 trans fluid level
moday
I had drained the trans fluid during a rebuild....I'm assuming the square plug at the rear bottom left of photo attached is the fill level to use (see
picture below) and it's not the hex bolt behind the brake pedal.
Please confirm as it's not real clear where the arrow is pointing to in my service manual.
thanks in advance, Moday
THanks....that's what I thought as I saw another hex bolt on the other side.
I know there is a dipstick for hydro but I need to check axle. I can't honestly recall if I drained that....another square plug on same side in back?
thanks, Moday
(quoted from post at 10:56:59 11/21/22) THanks....that's what I thought as I saw another hex bolt on the other side.
thanks, Moday
Way at the back on the left.
