Hello all ,
Having a no spark issue on a 3 cyl 3000 . Spring of 21 put a pertronix system and pertronix coil on to eliminate points. Tractor ran fine. Early this year started tractor to warm up ran about 5 min and died. Tried to start again would not fire. Replaced the pertronix kit and coil, new plugs, plug wires, new distributor cap still no fire. Only thing left is the solenoid but the starter turns motor over fine, so solenoid is is putting power to the starter. Can the coil wire post on the solenoid go bad.
