Noel Putman
I ended up splitting the 2000 3cyl this morning to sort out a non-working PTO. Only the 10 spline hub was operational. The 29 spline clutch hub was no longer attached to anything. The rivets had sheared off where they were connected to clutch material.
The question is, what else should I fix while it is split? I read somewhere that replacing the freeze plugs may be a good idea and also some seals. Are the seals the engine rear main and the transmission input shaft?
Thank you.
Thank you.
