Bern
- Location
- Mount Vernon, WA
As you can see, the owner of this tractor has a classic case of grease worm infestation on his farm. At least he got his money's worth out of the bushings. The slot from top to bottom is where I cut it out with a torch. The rest of it simply vanished.
There was so much slop in the spindles that they came out without even having to remove the woodruff key first. Surprisingly, even though the spindles were heavily pitted, they weren't worn all that much and new bushings brought it back to almost-new clearances. Yes, the owner is a tight wad.
