Will a ford 4610 loader fit onto a 4600
kimchris
New User
Im wanting a loader for my Ford 4600. Seen one advertised for a Ford 4610 and wonder if it will fit. Anyone know for sure?
This post was edited by kimchris on 11/03/2022 at 06:25 am.
It should be a bolt on... I can't say for sure if the bolt holes are exactly the same, but at most there would be some slight mods
to the bolster mounts I would think, provided the tractors are both like ie. both 'SU' or both 'AP'.
The tractors are the same physical dimensions so it should bolt right up.
Rod
(quoted from post at 16:21:24 11/03/22) It should be a bolt on... I can't say for sure if the bolt holes are exactly the same, but at most there would be some slight mods
Rod
Thank you. That s what I was hoping.
Mounts are the same from 4000 to 4630 providing the tractors are the same
SU models use 3000 style front axle assemblies requiring a different front loader mount than used on the standard all purpose models
Just make sure the front axle assemblies look the same on both tractors
(quoted from post at 18:06:49 11/03/22)
The loader is off the tractor at a dealers. So I cant tell what it came off other than a 4610. Sounds like it will basically fit and if it needs minor adjustment then that shouldn't be too much of a problem.
Thank you
We installed a 735 loader off a 4000 on a 4610, and since the flip-up nose is longer on the 4610 the loader had to be mounted forward a few inches. Since you are going the other way, I would think this
wouldn't be an issue.
