Noel Putman
I have a leak out of the left side of the power steering
column. It is coming out from around an eye shaped plate
with bolts 180 degrees apart if that makes any sense. There
is a threaded rod projecting from the center of this plate
with a lock nut on it.
Is this leak hard to fix or just a gasket issue?
Thank you.
Thank you.
