Fordfarmer
Finally getting back to the 7000 after
chopping corn and several days of odd
jobs.
Replacing the clutch went ok EXCEPT I
snagged the throttle rod when we were
rolling the front end away. Didn't think
much of it at the time, but when I hooked
it back up, I found out the lever on the
back side of the pump thatched throttle
rid attaches to got moved. The one
pictured is on a spare core I have. I
don't see any way to adjust it without
pulling the pump. Reading through the I&T
manual, it's a much more involved
procedure than pulling and replacing a
rotary pump on a 3 cylinder. Do I need to
follow the whole process if neither the
pump or engine will be turned while it's
out?
jobs.
out?
