LarryMaine
OK, rebuild is done, finally got timing correct and runs like a top. BUT. I am getting a serious oil leak between engine and housing. I obviously messed up the rear main seal. I did remove cam and cam cover plate, but that is not the problem. I will re-break the engine tomorrow and replace main seals, but, I have a newbie question. My rear mains seal kit included the side straight gaskets, two half moon neoprene main seals with metal rod inside, and two rope seals. According to a video I saw, I installed both the rope seals and the neoprene seals in the two round slots in the main bearing cap. However, in looking at other sources, it looks as tho one only needs to install the half moon neoprene seals and the side seals, and not install the rope seals, and thus leave the wider of the two round slots in the cap entirely empty. Was I wrong in installing both the rope seal and the neoprene seal? My other questions, as I don't want to do this a third time, is, should I use a small amount of high temp gasket maker anywhere on the cap or the gaskets, and if so where? All I used in the rebuild was some grease. Anyone with some experience in this would be much appreciated, as always. Regards, Larry.
