Ford 641 Rear Wiring
Steve in IL
Fixing up Dads 641. The rear wiring, for the 2 rear lights
and the trailer connector are in tough shape. Thought
that a rear wiring harness would be an easy fix But I
dont see anything. What have you guys done?
Initial look through the parts book shows part number 310993. Could not find that here, at Yesterday's Tractors. It looks like Dennis Carpenter has it for $58, but it's listed as fitting a 1937 Ford car. I guess I'll call them tomorrow, and see what I can find out..
HiYa Steve-
Glad to see youre restoring your dads vintage 641 and keeping it in the family. Lighting kits were never a factory installed feature always a dealer supplied optional accessory, until the 800 Series and then only headlights were used. The FORD p/n 310993 is the correct main wiring harness for the Utility/Trailer Socket Assembly, p/n FDN-14699-A. Carpenter makes exact wiring and parts ... did you look in the TRACTOR catalog? Its there. Denny also has the socket & wire connector for the trailer lamp, p/n NCA-13402-S. Fender brackets are slightly different for the Hundreds a bit taller. I have 3 OEM complete fender brackets with the Trailer Sockets in VG condition if you are interested, $25 plus shipping ... my email is open.
FORD TRACTOR 53-59 LIGHTING AND PARTS LIST:
Tim Daley(MI)
When working on my 961, I had the wires but no loom. I wasn't going to use the modern plastic corrugated and I finally found cloth wire loom at Mac's in Buffalo NY.
Nice looking 961! I am not going to get Dads old 641 up
to that standard! Just cleaning up, and fixing a few minor
things. Biggest thing to fix will likely be brakes They
work good, but the pedals do not return (come back up),
without pulling up with your foot. Any suggestions on
that? Thanks.
Have you lubed the pivot points and adjusted the brakes using the adjuster at each wheel?
