Into it because of a constant hiccup and a very poor position control. Probably found the hiccup problem as there were three bad o ring seals between the lift cylinder and lift cover, on half gone. probably
the reason silicone was found around the mounting bolt holding the cylinder to the lift chest. Will be an interesting situation we we try to get this very heavy cylinder mounted back into the lift chest with
the unloading valve check valve assembly protruding out the top of the valve assembly as the cylinder is splipped into the lift chest,(I hope?)Lot's of interesting situations her as I have never been into one
of these before. Are there any instruction around for adjusting the linkage? I do not have a shop manual. Have owned this tractor for 47 of it's 50 years and have never needed on till now.
