David Goode
I developed an oil leak where the left rear axle housing mates with the center casting. Figured it would be a simple fix and purchased new gaskets from YT. Having issues getting the gasket to fit, seems like the ID of the gasket is too small, and the bolt holes are not lining up. Has anyone experienced this problem before? Everywhere claims the gasket should be 12 15/16" ID x 15" OD, yet looking at my castings I think I would need a 13 1/4" ID X 15 1/4" OD gasket to fit.
Anyone see issues with resorting to silicon to create a gasket to seal? I assume it might mess of the axle end play and need to be re-shimmed.
Serial number on the tractor is 1620, which my research puts it as one of the first 641's off the assembly line in 1957. I'm wondering if I've got some non-standard axle housings as the castings don't match my parts manual.
Appreciate the help,
-David
-David
