1965 ford 3000 gas clutch problems
Mikecr78
New User
I have replace the clutch and pressure plate and threw out bearing. When I put the tractor back together and start it up I can't get it into any gears. I have adjust the clutch pedal rod. When it all the way out on the clutch rod I can feel pressure on it. But still nothing. What I'm I doing wrong.
Did you put the clutch disk in the correct way?? If in backwards it will not release guess how I learned that one
Check your linkage you may have a broke pin in the linkage letting the linkage to move and not push the throw out bearing as it should
You can't see a broken pin in the throw out bearing yoke or the pedal linkage you have to make sure there good and things don't slip on the shaft which you may not notice with it apart due t not putting much pressure on the pin area
When I open the tractor open there is nothing broken. I can put the clutch pedal down and watch the throw out bear move back and forth. The clutch fork has some wear on it. When I look at the pressure plate I can see marks on it from the throw out bearing. Thanks for the info too
Pressure plate fingers may need to be adjusted so they sit out more so the throw out bearing move them to release more
