Hi all,
Been searching high and low on this site and the internet but not much luck finding somebody who has posted a part number for a direct replacement for the original switch. I know the original Ford part number 313942 is obsolete and fits the 1959 to 1964 Select-O-Speeds. Also know the switch specifications are 1/8 NPT male thread, normally closed, single 1/4 spade terminal (grounds to switch body), and opens/closes at 2 psi. Maximum pressure it needs to handle is 12 psi. Only post I found with a part number suggested a NAPA OP6619, but cannot verify it opens at 2 psi, and Nason SM-2C-2F which I have no idea where you would buy that brand. There are tons of oil pressure switches on the web but very few actually tell you what the set pressure is.
Does anybody out there have a tried and proven switch part number that has a set point at 2 psi, will directly interchange (screw terminal could also be used), and won't break the budget. After all, this is just a simple idiot light. Thanks in advance.
