Hi. I have a Ford 1900 1983 that has the Shibaura 3 cyl diesel engine. It started to use quite a bit of oil (and is smoky etc) I suspect it has an issue with the Valves. Engine sounds good but it will use two quarts in about 1 hour of brush hogging! I was hoping to find a video on head rebuild as I am not sure how hard it would be be, I am in Oklahoma (Tulsa area). anyone know of a shop that could rebuild the head or a video. I will check the compression as soon as my compression test kit arrives. I would be very grateful for some help and thoughts on the oil burning and any other thoughts on things I can check. Thank you so much Jon
