Greg NE
- Location
- Duncan, Nebraska
My latest 4000 has me scratching my head. I have a single acting loader on this tractor and have the valve set for one way cylinders. The problem is that it seems to bleed down while it's parked and takes for ever to start to raise the loader the first time after starting it up. The 3pt goes right up starting tho. It's fine after that. The other thing is if I shut the tractor off with the bucket in the air it will not let me lower it to the ground unless I bump the starter. The biggest problem is if I pickup a decent load it will not go back down until I change the adjustment screw to double acting, then it drops like a rock. I have several of the same vintage of Ford's and haven't had this scenario before. Sorry for long post but I can't figure this out!!
E
E
