Anyone find a supplier for the longer flywheel bolts on the Ford 600 tractor with the single clutch? I see that this website sells the 0.8 inch bolts as does Steiner Tractor up here in Michigan. I see in the original parts manual that longer bolts are used on the single plate clutch. The first 3/4 inch of the bolts that I removed have no threads beneath the bolt head. It is listed as a 7/16-20 x 1.62 bolt in the book I have. I also understand that from my earlier note that no lock washers should be present but the ones I removed were a small head bolt with lock washers.
I also didn't have a ring (circle of metal) beneath the bolts but some tractors apparaently had that present. I'm less concerned with that as long as the bolts don't hit the block and I can get them torque.
thanks, Mike
thanks, Mike
