4630 mid mount weight limitations
vmaxpower
New User
i have a 4630 I am putting a front mounted smowblower on so I can't use front weights and it has no load in the tires. I have 2 sets of 10 75lb weights and brackets from a tree spade I would like to mount on the sides but haven't been able to find the ratings for those mounting locations.
There is no weight rating. Those mounting holes are plenty stout for pretty much anything you could hang there, as long as you keep the bolts tight of course.
I will be using this tractor mostly for moving heavy items on 3 point forks and snow removal in the winter i already have the 1500 lbs of weights that could easily be mounted. the tractor had a side arm mower that i can weld the weight brackets to the old mower brackets
for the winter it will have a 78" front mount snowblpwer and an 800lb heavy box blade on the rear. but most of the year I will mostly be maxing out the 3 point capacity moving heavy equipment parts and logs etc. with rear forks
