Reality Primate
New User
So I have an old 1988 Ford 555 backhoe, it lives in retirement, goes into the woods to dig up and push over a few Alder trees, but it has always shifted weird. I have to "throw" the lever hard to get it to shift, just took it apart far enough to see that the shift lever ball joint down under the fuel tank is sloppy, but damn, to get to it I need to remove the fuel tank......so sometimes I shift into reverse and it seems like it is delayed, other times I slam it into reverse and it goes right away. Today I was deep in the woods, nose first, and it took quite a while to get reverse.....weird thing is I know the clutches are strong, I could drag the space shuttle in reverse or foward.....is this just a linkage thing? The delay is weird, I can slam it into reverse, and after 20 seconds or so, it hits....looking at the shifter I can see that the last owned ground the slot bigger so there would be more throw on the lever......this must be a common problem?
