Story: About 20 years ago this Ford 5000 broke in a field and has sat 10 years in a shed and 10 years outside. My dad retired and moved, leaving me with the tractor. He told me that the last time he had it running it made a bad clanking noise. thinking I needed something to do I decided to start looking into it. For the last 2 years I have taken it apart and found that it had a spun bearing. Since then, I have rebuilt the engine; New crank, pistons, bearings, belts, hoses, starter, generator, (clutch since the tractor was already split) Injector pump, Injectors, and Wiring harness. Last week I heard it run for the first time since I saw it umteen years ago.
Now the question; it runs well at idle but seems to run rough or miss as I add RPM's. It starts to really struggle at high RPM's and won't even reach 2000 RPM's (about 1850 to 1900 is as high as it will go) I replaced everything but the head. (I did nothing but clean it up and put it back on). I have two thoughts. 1. could it be a Valve that is not sealing up? 2. the injector pump is new and has some adjustment. do I need to advance the timing slightly, (since it runs well at low RPM's)? OR maybe it is something else completely. I wanted to put it out there and ask for thoughts and ideas. Thanks in advance for your thoughts.
