Ford/New holland loader help
Recently picked up a ford 7840 4x4 with loader. It's the sl model open station, I have to replace a few lines on loader but am un able to identify it as no markings or tags on it. I've never seen one with 4 rams on bucket tilt and 4 rams for lift before lol
It probably is/was a 7412 but I think you'll find the extra cylinders are a homespun innovation.
Rod
The double cylinders give you extra lifting strength at the price of speed. I agree that it looks like the double cylinder setup was done by some previous owner, and so I wouldn't order hoses from New Holland based on the model of the loader. I would just remove the ones that need replacing from the tractor and take them to a local hydraulics shop to have a set made up. It will probably be cheaper that way anyway.
(quoted from post at 12:05:58 05/21/22) It probably is/was a 7412 but I think you'll find the extra cylinders are a homespun innovation.
Rod
I found the tag it was painted over , it's a 7413 ford loader
I am trying to find a bucket for it as there isn't one for it. The lines are going to the hydrolic repair place to have all of them re done. And upon further inspection the added rams are of a previous owner add on. Whoever did that did do quite a good job welds seem nicely done not a hack job for sure lol. There is a 3rd function or remote quick connects mounted in center of loader arm and the mount and controls are in good shape too.
