I have an issue I'm trying to pin point
the culprit. I've rewired the tractor
correctly. I'm looking to switch it from
12 volt positive ground to 12 volt
negative ground. I was told by a tech
support representative that all I need to
do is switch the battery cables around and
the coil wires which I did. Then the
solenoid started smoking I disconnected
the negative battery cable. I'm wondering
if it still has a 6 volt regulator or if
the push button they installed is back
feeding? How do I tell if the regulator is
6 or 12 volt? Or I'll just put it back to
12 volt positive ground. The tractor was
converted from 6 volt to 12 volt by the
previous owner. The only thing is they by
passed the neutral safety switch and
installed a put button and wired it to the
S and I terminals on the solenoid
