4x4 Ford 5610 / Loader
They're a good tractor. Clutch can be a bit light on the older ones for loader work. Under powered a bit probably. Keep the oils/filters clean and rad clean and they work good...
Dirty hydraulic oil and they can give you lots of misery.
Rod
If it a early blue strip model with integral power steering you don't want to force the steering while setting still with a load on the loader
I've known of a coupe of 4x4 models with loaders that broke the steering box
If it a later black strip series II model it has hydrostatic steering and is a good tractor to have
