fixing farmer
New User
I'm having a problem with this head gasket leaking externally as well as internally(found oil to be milky). Coolant is leaking at seam of block and head. Both were sent out and machined. All bolts and threads were cleaned and tapped. I removed one bolt thinking maybe coolant was wicking up the threads. When removed coolant flowed out bolt hole. My question is should sealer be used one these bolts and could this be my problem? So far shows no sign of gasket failure to combustion. But am questioning coolant getting to oil from this as well. New gasket ordered from CNH other is from reliance. Thank you for any help. Wanna make sure this doesn't happen again.
