The ball joint on the rear of the drag link for the steering on my 3000 was getting loose. I have ordered a couple aftermarket ones but haven't been able to find one the correct length or with the correct size threads on the front of it. I can seem to find one or the other. The tractor has power steering. I've got a C5NN3307H that is the correct length of 32 inches but it has 1 inch diameter threads on it. The drag link that was removed was the same length of 32 but had 3/4 16 threads that went along with the C5NN3349A connector tube. The other side drag link also has the 3/4' ball joint connector tube on the front. Any insight?
