ford4500ri
New User
The Ford 4500 is not starting after sitting for the winter a couple of months.
I went to try and bleed it, and I'm getting fuel out the top of the filter, and fuel out the bleed screw on the body of the Cav, but no fuel at the injectors, and no fuel at the injector line at the Cav if I loosen/remove it there, not a drip.
Cranked the engine quite a bit and nothing on that side of the Cav.
Whats the next step, or likely cause?
Time to take the top of the fuel pump off and check something?
Thanks in advance.
Thanks in advance.
