Having a problem with the front loader not wanting to lift unless you run theengine at full throttle. All other items like the rear 3 point hitch lift and the front bucket work fine. Checked fluid level and all is okay. When I get the front loader without any weight in the bucket up the bucket operates okay. Its just when I want to raise the front loader you have to rev the engine to lift butis very slow. Seems like a fluid restriction maybe thru the control valve (lever). Any ideas as to what might be the problem? Clogged hose or line?
If your bucket works crisply then it has to be in the controls. First take a look that a stick isn't jammed behind the lever keeping it from traveling as it should.
Tom there is no stick stuck anywhere. The Bucket works well as does the power steering and the box blade attached to the rear. Disconnected both lines to the lift cylinders and has a good flow of fluid there.
Don't have pressure gauges to connect to these lines. The problem almost has to be in the lift control. It has double spool control valve. Could there be something wrong in this valve?
(quoted from post at 20:56:20 05/03/22)Any ideas as to what might be the problem
Possible fluid bypassing worn out cylinder piston packing's.
Google "End of stroke bypass test"
