snafflekid
It's me again! I had the flat tire with the leaking ballast fluid. What a mess, and of course the floor jack was bad too and would not lift the rear end. So, I swapped the valve core with the valve stem in the down position and of course lost quite a bit of fluid from the flat tire. As it turns out for my purposes I don't need the fluid. I plan to dump an equal amount of fluid from the other tire and call it a day. So far the tire is holding pressure. This has been a comedy of errors getting that tire fixed.
I charged the battery expecting it to be bad, but I got the tractor to turn over. The tractor is gasoline and had fuel stabilizer in it. The beauty started up after a choke. About 30 minutes of mowing it started sputtering and died.
I removed this which I think is a fuel filter bowl. It had a lot of junk in the bottom that I cleaned out. The tractor started up but I hurried back to the barn to work on it there.
What do you recommend I do first? Is there a fuel filter on this? open the carb and clean it? Just use up the gas that is in the tank and then get a fresh tank? What is the easiest way to drain the tank?
Upon closer inspection I notice that mice have had a field day gnawing on rubber covers and packing the body with acorns and pecans. The varmints even ate some bondo off a repair on my 8N. :evil:
