Hello, i mounted a loader on my ford 1320 and need help plumbing the hydraulics.
I am using this spool valve assembly
The ford has a diverter block with 3 ports and a selector screw that takes a flat head. My understanding is that the selecter screw enables you to switch hydraulics from the rear to the loader.
All of the hydraulic rams are hooked up but i cannot figure out how to hook the spool valve to the tractor.
Any advice would be great. Thanks
