Ford 4000 rear main
73 ford 4000 gasser. I have the tractor split already for a clutch job but was curious to replace the main do you have to take the oil pan? Would rather not have to re rig the front half of the tractor if possible to drop the pan. Thanks
Nope. Remove flywheel and rear engine plate. Pry out old seal with a screwdriver and carefully press in the new one. I use the old seal as a driver in the absence of the proper tool.
