Ford lift hydraulic cylinder
Andy_810
Anyone have any idea what size screw would thread into the end caps on this hydraulic lift cylinder, the vales are stuck.
The top one take plate off on other end, then use punch about same size. bump out to open end of cyl. The other plugs are #10-32 use socket head capscrews.
This part came off my 420, same as a 4600. I was able to drive the top one out. The caps ended up taking a 8-32 X 1 inch screw. I used the black allen head machine screws with a fender washer and nut. A pry bar and alot of gentle tapping and I got all 4 of them out. I am surprised that the bolt size was so small unlike a 3000 that takes a 3/8" fine thread bolt. Thanks!
