johnboyz
New User
Have 801 has 200lbs pressure on hyd pump
liftt does nothing my question is how much
pressure should it have @ pump & what
should I check next.
(quoted from post at 14:58:52 04/20/22) Have 801 has 200lbs pressure on hyd pump
ressure all depends on circumstances. For example, if the unloader valve is in unload position, the pump output is being dumped back into the sump via a backpressure (low pressure} valve, with nothing going to the lift cylinder. Study & understand the flow circuits. If you take measures to block off any pump flow other that via overpressure relief, you should see 2000-2200PSI
0
Correct. Moving the lift or draft
levers does not affect pressure in any
way. Plug in lift cover where valve
would go has very little flow & no
pressure. My question is Would it be
valve etc. & can it be fixed through side
plate like 8n etc.
