The PTO brake is not fitting I have pictures but I can't seam to post them(quoted from post at 02:06:18 04/20/22) I can not get the parts to fit back into the tractor right I replaced the PTO clutch and brake. The tractor is a mid 1960s f5000.
The PTO brake is not fitting I have pictures but I can't seam to post them. The transmission has 8 gears(quoted from post at 02:06:18 04/20/22) I can not get the parts to fit back into the tractor right I replaced the PTO clutch and brake. The tractor is a mid 1960s f5000.
how do I get 7-10 posts(quoted from post at 02:06:18 04/20/22) I can not get the parts to fit back into the tractor right I replaced the PTO clutch and brake. The tractor is a mid 1960s f5000.
(quoted from post at 23:22:31 04/19/22)how do I get 7-10 posts(quoted from post at 02:06:18 04/20/22) I can not get the parts to fit back into the tractor right I replaced the PTO clutch and brake. The tractor is a mid 1960s f5000.
(quoted from post at 03:22:31 04/20/22)Thank you for the Help(quoted from post at 02:06:18 04/20/22) I can not get the parts to fit back into the tractor right I replaced the PTO clutch and brake. The tractor is a mid 1960s f5000.
I am not sure what year the tractor is. Great grand dad left the farm in 1969 and it was his at the time.
Looks like that did the trick Thank You(quoted from post at 16:34:09 04/20/22)
It's been a few years since we repaired the pto in that 5000 but I'm thinking the pin goes in a hole in the valve below the brake spring hole, that would raise the valve up to where it needs to be
Check it out
