1967 Ford 2000 Remote Hydraulic Leak
Hey folks - relatively new owner here. I just purchased and installed a single spool hydraulic remote in front of the seat to be used as a top link adjuster. The installation went smoothly, however noticed that there's at least one tiny leak where the control unit mounts to the chassis. When the tractor is running I can see a bubble on occasion.
I suspect maybe a spec of dust (I was careful to clean the mounting area after removing the old cover, but perhaps not careful enough), however wanted to ask and find out from more seasoned hydraulic folks if there's any other possibilities. Perhaps the bolts aren't at the right torque? (Didn't want to over tighten them either)
I'll hopefully have removed and cleaned up all connection points again this evening. Hopefully that helps, but if anyone has any other thoughts on things to check, I'd appreciate it.
Best Regards
Is the leak where the body of the valve bolts to the top cover? How did you keep the o-rings in place? If an o-ring moved it might have gotten pinched.
Yes that's correct - the leak appears to be where the body meets the cover. The o-rings were already installed and appeared to be well-set, but I'll take it off and
inspect it carefully to make sure that's not the case.
Thanks much for your help!
I'll post an update as soon as I can.
(quoted from post at 14:22:34 04/19/22) Yes that's correct - the leak appears to be where the body meets the cover. The o-rings were already installed and appeared to be well-set, but I'll take it off and
You should use new o-rings every time that you remove the original blocking plate or remote valve. My bet is that one of those original o-rings is leaking due to age. Use grease to hold the new o-rings in place as you put the remote valve back on.
Sorry for any misunderstanding, most likely on my part. When you said "The o-rings were already installed and appeared to be well-set" I thought that you were referring to the old o-rings.
Well, tried again by removing the control valve, cleaning the mating surfaces and re-seating. I checked the O-rings while placing the control valve to make sure there was no pinching. Problem still exists where oil is leaking where the two surfaces come together while the tractor is running.
2 questions for the group:
1) Does anyone know the effective torque needed for the bolts? I don't want to overtighten but that may mean I'm not supplying enough.
2) Should the mating surfaces be oil-free when installing, or does that matter at all? I was having trouble keeping hydraulic oil off of the surfaces when re-attaching the valve.
Did you get it figured out? I’m having same issue.
He might be hanging around, or using a different handle, and might answer you, but it looks like he was only around one day. If you hover over or click on someone's avatar it will generally tell you when they joined and when they were last seen (logged in) to the forums.
You will likely have better luck if you start your own thread. Give your tractor model, any pertinent info about it, the issue, and what you have done so far. Some people will see the date the thread started and just pass on by it. Others may start addressing the first post of the thread and never look at your post
Are you using the bolts that were with the assory plate or the one that came with valve? They may be bottoming before they are tite.
As mentioned above check bolt lengths. I purchased one of those valves and didn't like the bolts or their lengths so I bought new bolts the correct length.
