grisle_mcthornbody
New User
Hey folks - relatively new owner here. I just purchased and installed a single spool hydraulic remote in front of the seat to be used as a top link adjuster. The installation went smoothly, however noticed that there's at least one tiny leak where the control unit mounts to the chassis. When the tractor is running I can see a bubble on occasion.
I suspect maybe a spec of dust (I was careful to clean the mounting area after removing the old cover, but perhaps not careful enough), however wanted to ask and find out from more seasoned hydraulic folks if there's any other possibilities. Perhaps the bolts aren't at the right torque? (Didn't want to over tighten them either)
I'll hopefully have removed and cleaned up all connection points again this evening. Hopefully that helps, but if anyone has any other thoughts on things to check, I'd appreciate it.
Best Regards
Best Regards
