Hello all, this is my first time posting, but this forum has been invaluable in keeping my Ford 3000 running. Thanks to all who share their knowledge!
I have a 1968 Ford 3000 diesel that needed the power steering cylinders replaced. So I ordered some new aftermarket cylinders and re-plumbed all the lines. The good news- no leaks; the bad news- the steering isn't working properly. The lines and the cylinders all warmed up after going through the self bleeding procedure, so I don't believe the issue is with plumbing. I think I have crossed up lines. The original set up worked on the tractor, but it was a sorry sight of an ugly aftermarket cylinder and an original that had been welded back together. Basically I don't trust the old plumbing order. I looked in the shop manual and the lines are not very clear on the diagram and I am a little skeptical anyway because the originals were a "right hand" and "left hand" part and the replacements are reversible. I found a post describing how to run the lines on a 3600 and that's how I did it. The steering is very stiff so I think the cylinders are "fighting" each other. I only have 3 more combinations to try, but I don't want to ruin the steering components by testing.
Basically there is a fore and aft port on the side of the steering column and a inboard and outboard port on each cylinder (right and left). Has anyone done this replacement on their tractor that can guide me on the right order of things?
Thanks!
JP
Thanks!
JP
