Ford Jubilee Hydraulic Pump?
All NAA/Jubilee tractors left the factory with the vane style pump. They changed to the piston style pump at serial number 66849 of the hundred series (they reset the starting serial number for each new series).
Some NAA/Jubilee tractors have had their vane style pumps replaced with piston style pumps ovr the years though, so the answer to your question is.... you will need to look at it to see which style pump it has.
This post was edited by Sean in PA on 04/15/2022 at 10:50 pm.
(quoted from post at 21:39:18 04/15/22) Does a Ford Jubilee with a serial number of 105746 have a vane or a piston hydraulic pump?
Hard to say what you have after so many years. It could even have a gear pump. Mine does, but my engine (192) came out of a Jacobson G-10 mowing machine.This same pump will fit a 134 engine.
Thanks to all who have replied. Thanks JMOR for presenting the pictures which show the difference in the hydraulic
pumps. The tractor I am working on is definitely a piston pump, according to the pictures.
