I was recently helped by a number of you with clutch issues on a 640. Thank you. I have since put in a new kit with pilot bearing, clutch, pressure plate and release bearing. The issue I am having is that the release bearing does not come forward far enough to reach the fingers on the pressure plate. I remember another post some time ago by someone with the same issue. There was a response recommending washers be put behind the pressure plate to move it out further. Of course longer bolts would be needed. Does this sound like a sensible solution? It was stated that many of the plates made today are not as thick as the old ones. Any words of wisdom will be appreciated.
