I'm trying to keep the tractor 12 volt but
make it negative ground. I'm not looking
to spend a lot of money. Can I take the 6
volt generator off and put a 12 volt
generator on? What wires need to be moved
around to go from 12 volt positive ground
to negative ground also can I use a 12
volt coil with an internal resistor and
eliminate the external one that's already
on the tractor? Thanks for the help
