Tom Bowman
Replacing the bulbs on a Ford 860 with Tract-O-Lite headlights and worklight.
One of the old sealed-beam bulbs (lamps) is stuck in the headlight housing. (The other headlight bulb and the worklight bulb came out easily.)
Tried gently tapping on the back of the housing, and even carefully prying on the back of the bulb with a thin screwdriver, through one of the slots along the rim of the housing. (Yes, the retaining ring is removed.)
Has anyone else run into this?
